Re: 450 power on/off pull switch
Posted by old on November 13, 2007 at 07:22:57 from (4.244.57.234):
In Reply to: 450 power on/off pull switch posted by David Robinson on November 13, 2007 at 06:06:35:
From what you say sounds like the loose wire would go to the switch or to the battery in some way. The 3 wires need to be traced down to see where they go, but they probably go to lights or something like that and of course you need power in to make them work, but if the lights are 6 volts they will blow almost as soon as you turn on that switch if you hook it up
