Re: 3/4 IH updraft carb
Posted by Bob M on November 13, 2007 at 07:27:50 from (151.190.254.108):
In Reply to: Re: 3/4 IH updraft carb posted by 300Randy on November 13, 2007 at 06:46:20:
Randy - Look for a a small (5/8" diameter or so) circular brass tag with the part number stamped into it. It will be riveted to the throttle body casting. The tag is likely covered with many years accumulation of varnish and dirt - you'll probably need to scrub/wire brush the throttle body to find it.
Incidentally the carb number MAY be 356 065 R92, though I am 100% certain. However a kit for the above will work for the carb on your 300U.
