Re: Super C hydraulic pump
Posted by Janicholson on November 13, 2007 at 09:38:09 from (199.17.6.122):
In Reply to: Super C hydraulic pump posted by wstewart7 on November 13, 2007 at 06:56:37:
The info below is good, there is also a possible oil pump with a "O"ring seal. It is good to go with a new "O"ring if the shaft is not grooved. If the shaft has a groove that can be felt with a fingernail, the speedy sleeve is needed, and the housing must be bored to allow the sleeve to be put in, and the sleeve must be put on after the pump is assembled dut to the sleeve not going through the bearings. JimN
