Re: fixin an h grille...with pics!!
Posted by NawlensGator on November 13, 2007 at 11:22:03 from (52.129.8.50):
In Reply to: fixin an h grille...with pics!! posted by glennster on November 13, 2007 at 05:46:51:
Nice!! What welding technique will you use? If stick, what rod size (6018/7018?).
I would not have put the vertical sections at the ends. Why not weld a strip behind and all the way across the opening for support, then a shorter piece on top of it welded to the back support and also at the edges to the existing metal? Just curious, I think it looks fine, and thanks for sharing.
