Did you have this engine block dipped and all oil passages cleaned? I would check that oil pump to make sure the key hasn't sheared. If you sat that pump in a clean container of engine oil and twisted that drive gear until oil was being discharged it should be primed. You may need to blow out those oil passages with air. I wouldn't run that engine until you get pressure. Do you think the filter is full? If that pump was rebuilt that's the place where I would start. With a primed pump you should have almot instant oil pressure. If you can find a pressure vessel similar to the Wagner brake bleeder ball you can fill that complete oil gallery with engine oil until your tractor's oil pressure gauge shows oil pressure. Then make a start and let the engine idle and see if there's oil pressure on your gauge. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
