Re: IH 706 No Oil Pressure
Posted by K.B.-826 on November 13, 2007 at 16:11:44 from (24.180.146.150):
In Reply to: IH 706 No Oil Pressure posted by Shawn P on November 13, 2007 at 09:48:40:
Are you using an actual guage, or are you going by the idiot light in the dash? Keep in mind that on an 06 series tractor, the idiot light is for both engine oil pressure and transmission pressure. If you're holding the clutch pedal down, the MCV dump valve will be open to dump oil pressure out of the TA clutch, causing trans pressure to drop and the light to come on. This is normal. Could also be a MCV problem. Eliminate this possibility by disconnecting the trans pressure sender. It is located on the rear side of the MCV, which is located on the left side of the clutch housing. Now, if you're using an actual gauge and you have no pressure, try Jim's method of priming the oil galley.
