Re: Hydraulic PSI
Posted by edward_m on November 13, 2007 at 20:04:52 from (67.55.240.130):
In Reply to: Hydraulic PSI posted by wallacedw on November 13, 2007 at 19:08:37:
I don't think you have to worry....2500 PSI is probably the max the unit is designed for. If your under that, it just means you cant lift as much.
My Dad has a Westendorf loader on a 666 IH, and the hydrolics limit out at less than a 2000 pound load. I think it has allot to do with the load PLUS the loader weight that limits him (its a big loader). Plus the 666 pump might be a little weak: after all, the tractor is only 33 years old.
A 400 didn't have the highest pressure either.....I mean, what did they use back then that needed that kind of pressure?
