Re: B timing
Posted by Terry Therneau on November 15, 2007 at 07:44:07 from (129.176.151.7):
In Reply to: Re: B timing posted by Bob on November 12, 2007 at 19:56:41:
Many thanks to Bob, who said
"...the mag"s impulse should trip when the drive lugs are horizontal."
This is exactly what I needed to know. Mine trips when the lugs are vertical. I"ve got the magneto service manual thanks to another link, and will examine the impulse coupline. Perhaps a key has sheared or something.
Terry T.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
