Re: Farmall M Main :SKF!!
Posted by GertM on November 15, 2007 at 07:50:49 from (217.166.9.11):
In Reply to: Farmall M Main Shaft Pilot Bearing posted by GertM on November 13, 2007 at 13:35:24:
Hi Folks,
there is a good more valuable solution for the Main shaft bearing.SKF has a bearing in standard programm:The NU2205ECP witch is cheap,great quality and can be mounted easily.Is 2 mm.shorter but the ebaring doesn't get big axial forces so this works out with a little loctite.
De cylinder however are on outside and separate inner ring on shaft.Just the way around as tyhe original.
When it's worn I will be in elderly-people home by then.My MV will be on the old iron pile..haha!!Thanks for sharing ideas
