Re: ih 966 hydraulic problem
Posted by the tractor vet on November 15, 2007 at 08:41:51 from (76.212.227.88):
In Reply to: ih 966 hydraulic problem posted by DannyP on November 15, 2007 at 07:50:26:
If the three point and remotes just up and stopped working then there is a good chance that ya sheared the key on the main pump . Drain the rear end and remove the pump , then remove the gear and see if the key sheared . But if what ya say about the steering and brakes not working wright here as not sure what ya mean for sure . Before ya do anything then check and make sure that the PTO is still working under load . If that is not working them my best guess here is ya did what i did last friday and took the center out of the pressure plate and maybe along with the PTO input. IF this is the case then a split at the bellhousing is in order . Hard to fix a tractor over the keyboard with out checking it out first. Don't think it is a valve .
