Will a hotter coil solve the problem? Probably not…
If cleaning or replacing plugs temporarily cures the misfire, the problem is not likely the coil. In fact installing a “high voltage” coil may even make it worse.
Suggest rather you look at the following:
Spark plugs’ heat range is too cold. Switch to plugs 1 – 2 heat ranges hotter than what the manual suggests. (Note: This is a common problem when you combine extended operation under light load - the “yard work” you mention - with the poor quality gasoline we’re stuck with today.)
Carburetor is set too rich. If you see any trace of black in the exhaust – especially at idle - it’s too rich!
If you use the choke to start the cold engine, get the choke opened and the engine under load as quick as possible. (Excessive choking on a cold engine fouls plugs VERY quickly…)
Make sure the engine’s thermostat is present and working. A cold engine lightly loaded tends to foul plugs.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
