Re: IH 706 No Oil Pressure
Posted by El Toro on November 15, 2007 at 15:46:19 from (64.12.116.73):
In Reply to: Re: IH 706 No Oil Pressure posted by Shawn P on November 15, 2007 at 14:23:18:
Do you have a pressure gauge on the oil gallery?
I would pull the oil pump and blow compressed air thru that hole in the block where the oil pump mounts. You need open any plugs so the sludge or dirt can escape when you use air pressure. You will need a helper. Are you sure you have oil level to the full level? It bothers me about that rebuilt pump. You should have instant pressure since you primed the pump. If you can't find the problem I think I would call steelwheelranch and see if they have a good used pump. 785-548-7437
Hal
PS: Did you have pressure before the rebuild?
