Try a different guage? About the only other possibilty at this point is a problem with the oil cooler bypass valve or the pressure regulating valve, both loacted in the filter base. Maybe a blown gasket between the block and filter base. Sure you got the pump together right? Possible that the gear inside is spinning on the shaft. Pull the pump back out, stick it in a pail of oil and turn it by hand to verify that it pumps. Have you actually started the engine, or are you just cranking and trying to build pressure?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
