Re: Update: IH 706 No Oil Pressure
Posted by Janicholson on November 15, 2007 at 17:18:36 from (66.173.50.139):
In Reply to: Update: IH 706 No Oil Pressure posted by Shawn P on November 15, 2007 at 15:42:38:
If you primed it the way I suggested (with an oil can) did there come a time that it felt different, the pumping got harder, or changed?
If not, there is no telling where the pressure is going.
I would pull the oil pan and valve cover. With these off, I would use the priming system you used to put oil in the system to put more oil in the gallery. (a helper might be needed) Watch the crankshaft and cam from under neath, and the passages where oil might be found.
Look also at the head/valves to see if there is a hemorrhage there. An oil gallery plug or a core or drill plug left out from the cleaning process can do the deed. Looking at it will find it. JimN
