Re: 1969 farmall 656D, please help me make a decision
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by TREEMAN on February 22, 2000 at 14:40:26 from (207.234.108.98):
In Reply to: 1969 farmall 656D, please help me make a decision posted by matt on February 21, 2000 at 19:55:24:
IT SOUNDS LIKE A GOOD DEAL TO ME. I HAVE AND RUN FIVE OF THEM. THREE OF THEM HAVE THE SAME PROBLEM OF JUMPING OUT OF GEAR, BUT IT UNDER A REALLY HEAVY LOAD. THEY WORK GREAT FOR HAY. YOU WILL NEED A LITTLE BIGGER TRACTOR IF YOU ARE GOING TO BE ROUND BALING ON A STEEP HILL, BUT ON SMALL HILLS AND FLAT GROUND THEY ARE PERFECT. FOR US THEY ARE JUST THE RIGHT SIZE FOR MOVING HAY AND FEEDING WITH ALSO. GOOD LUCK.
Post A Followup
: Re: Re: 1969 farmall 656D, please help me make a decision
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
