Re: Update: IH 706 No Oil Pressure
Posted by Brownie450 on November 16, 2007 at 03:59:28 from (207.177.82.156):
In Reply to: Update: IH 706 No Oil Pressure posted by Shawn P on November 15, 2007 at 15:42:38:
As JIm said--" Have you had the valve cover off & seen if oil is getting to the upper end"? Oil will take the route of least resistance, & if there is an opening in the valve area, oil won't build up pressure in the galleries until leaks are stopped. Just a thought-- are you sure that the oil pump is turning? Don't remember for sure---is there a roll pin or solid pin in the drive gear on the oil pump? Maybe pressed on--- don't remember...
