Re: Update: IH 706 No Oil Pressure
Posted by El Toro on November 16, 2007 at 04:45:07 from (205.188.116.73):
In Reply to: Update: IH 706 No Oil Pressure posted by Shawn P on November 15, 2007 at 15:42:38:
I think the oil passages are plugged with sludge or dirt. That's why we recommend having the block dipped and all oil passages blown out with air. That's a good time to have new cam bearings installed too, close tolerances on them determine good oil pressure. Pull the pan and pump and connect an air line into the oil gallery and see if you can blow air out where the pump connects.
Hal
