Re: IH 706 No Oil Pressure
Posted by El Toro on November 16, 2007 at 07:43:14 from (64.12.116.73):
In Reply to: IH 706 No Oil Pressure posted by Shawn P on November 13, 2007 at 09:48:40:
I would pull that pump and reprime it again and reinstall it, put the pan on with a few bolts and fill the crankcase with oil. Then crank the engine again and see you have oil pressure. I would install a new calibrated gauge that's graduated in psi. You may have lost the prime by the time you started the engine. Hal
