300U dying out
Posted by Spook on November 16, 2007 at 10:38:32 from (75.45.88.78):
I have a 300U. I am having a problem with it running, It gets started, runs a little rough, will run for a couple of minutes, then starts sputtering and quits. I thought it might be the fuel system so I have done the following:
1) Cleaned the sediment bowl. There was some gunk, not much.
No result.
2) Cleaned the tank. No result.
3) Replaced the fuel line. No result.
3) Took off the air intake, squirted carb cleaner in. No result.
Now do I take the carb apart, or look at the ignition system?
Thanks for the help!
