Re: 1066 lube problem
Posted by the tractor vet on November 17, 2007 at 13:46:11 from (76.212.227.183):
In Reply to: 1066 lube problem posted by Kevin Meier on November 16, 2007 at 13:52:25:
Well if ya would have asked me here i would have told ya just what he did . As for the pinched wire welllllllllll maybe but that does not cause then to self shift . And since it was done by a DIY and i'll lay a dollar to a donut that they have never done one before . So did they set the quill end play ??? did they have there grubby finger in the MCV?????? Did they PULL the tractor together with bolts ?????? And just how did they check the pressures , do they have the special test tool or are they just checking pump pressure. And just what do they have for pressure . DID they do the clutch , trans brake and dump valve like i have told so many how to do it ??? . This falls under DON'T TRY THIS AT HOME LEt the trained pro's do it and you will save money.
