Re: Woods belly mower experts
Posted by gene bender on November 17, 2007 at 15:46:53 from (67.55.226.214):
In Reply to: Woods belly mower experts posted by Hugh MacKay on November 17, 2007 at 15:32:28:
Those bearings are pressed fit and you need a good press to remove them. Not expensive but when replacing need to make sure they arent too tight.as the top one has to bee in the rite place as the little sleeve has a pin to hold the shaft in position.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
