Quite possible that the clutch disc had bonde to the face of the flywheel. Four months does't seem like a long time if that is the problem. You could try getting it into gear at low idle or starting it in gear to get it running. If you've got good brakes, once you get it moving under its own power you might be able to break it loose by pushing in the clutch pedal and banging on the brakes to break it loose.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
