Re: stuck clutch
Posted by ScottyHOMEy on November 18, 2007 at 10:54:00 from (71.241.213.254):
In Reply to: stuck clutch posted by LA in Wi. on November 18, 2007 at 10:30:13:
Can't hurt, might help. The times I've done it, I blocked it after the tractor ws parked bt still running, thinking that *might* allow the disc to float to some spot between the pressure plate and flywheel. That would lessen the chance of the disc facing bosnidng to anything and, with luck, would give a little play in case the center shuld stick to the shaft. Letting the pedal back out would break it loose in that case.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
