Re: Farmall B - crisped wire
Posted by Dave H (MI) on November 18, 2007 at 16:51:28 from (64.12.116.73):
In Reply to: Re: Farmall B - crisped wire posted by Hugh MacKay on November 18, 2007 at 16:20:21:
Hugh, I would like to tell you this tractor has anything even close to a nice wiring harness on it. Closer to a bunch of Radio Shack cut-to-length quick fixes running hither and yon. The stuff I have already replaced is pretty slick with good quality connections, etc. I am not nearly as intimidated by electrical stuff as I am by plumbing. I rebuilt a 1953 Seeburg about ten years back so I could listen to Sinatra and Bennett the way they are s'posed to sound. Guess time is here to replace those few last wires!
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
