Re: Farmall M Bearings
Posted by D Slater on November 19, 2007 at 16:50:31 from (72.65.155.230):
In Reply to: Farmall M Bearings posted by Mike Farmer on November 19, 2007 at 12:59:56:
You may not want to hear this, but the IH M crank was surface hardened on the journals and anything past .030 off the journals is likely to get past the hardened part. May be different where your at but a M crank can be found pretty cheap that will clean up at .030 or less in some places. Shipping may be high and I don't know how good it is but there's one in the classified for 35 dollars. You could also upgrade to a late M,SM,400 or 450 crank, just use the bearings for the larger jounal crank in the M block.
