Re: 1586
Posted by nates90 on November 20, 2007 at 05:16:33 from (216.16.61.224):
In Reply to: 1586 posted by frdtrck on November 19, 2007 at 18:29:45:
Not sure what size it would pull. Blow by is the air that comes out of your crank case breather, excess amount means that the compression from your cylinders are leaking by the piston rings causing it to blow. Normal blow by is if it is blowing a little bit of steam....i would say it would blow it down about 2-3 inches when idealing i think. Be interesting to see what other people think, never seen what a fresh engine does.
  • Re: 1586 Owen Aaland 15:08:01 11/20/07 (0)
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
