Re: Where to buy Ballast Resistor
Posted by Bob on November 20, 2007 at 11:07:46 from (69.178.229.154):
In Reply to: Where to buy Ballast Resistor posted by David Robinson on November 20, 2007 at 10:42:00:
As the others say, a MOPAR unit is pretty close.
Myself, I would at least price one through the CNH dealer, and use the "real thing" if the cost is not too prohibitive. (At least if you are still "running" the original coil.)
The resistors DO vary a bit between applications.
The 4-cylinder MAY have more "dwell" than a 6 or 8 cylinder unit (due to the 3 of cylinders AND the distributor cam profile), and the ballast resistance and the coil MAY vary a bit, accordingly. This IS true for some applications, I can't say for SURE for this one.
ANYHOW, the OEM unit is the safest bet, especially if the cost isn't TOO prohibitive.
