Re: Framall B Stalls
Posted by gene bender on November 20, 2007 at 13:15:57 from (67.55.226.214):
In Reply to: Framall B Stalls posted by Dave Ulm on November 20, 2007 at 12:54:37:
Does it have a mag or a dist? When it stops check for spark. Just pull a wire off and stick a screwdriver in the end that goes to the spark plug then holding it next to the steering shaft and turn engine over to check for fire.If you have a mag you will have to pull the mag to repair. Check the position where the rotor is pointing so you can install with it the same position.
