I've taken a few flywheels off using some heavy angle iron. I use two pieces and line them up with those three holes in your flywheel. The angle iron will rest against the bell housing. Then get yourself some threaded rod and some nuts to fit those threaded holes in the flywheel. Screw the threaded rod into those holes and use the nuts on the other side of the angle iron to pull the flywheel off. Just make sure you use equal pressure. Only the nut and pressure hold the flywheel on. I would not mount the engine stand to the flywheel. Just what I do.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
