Re: 606 engine quits
Posted by bc on November 20, 2007 at 21:04:20 from (69.151.187.126):
In Reply to: 606 engine quits posted by ban45 on November 19, 2007 at 07:11:39:
Hi, I have been having similar problems sometimes with my 2606. I believe I have all the fuel problems taken care of. Sometimes starting up a hill in 2nd or 3rd it won't go without stalling out, and then have to shift down to 1st.
I will check again for a manifold leak. I have some fresh oil around the exhaust manifold which suggests that may be leaking but is no noisy hot air coming out suggesting an exhaust leak.
One way to check for an intake manifold leak is to take a spray can of starting fluid or carb cleaner (carb cleaner may be safer) with a short tube stuck in the nozzle and spot spray all around the manifold and carb gaskets, etc. If there is a leak that is sucking air, you will hear the rpm's pick up when spraying at the leak.
This is a trick I learned regarding leaking vacuum hoses on new cars and trucks. Spraying around leaking, cracked, etc. vacuum hoses will cause in increase in idle. You can then isolate the cause.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
