Posted by City-Boy McCoy on November 21, 2007 at 04:42:18 from (209.214.105.177):
In Reply to: H Carb problem? posted by Stevishere on November 21, 2007 at 04:12:25:
Stevishere: It sounds like you may not have let it soak submerged long enough in some powerful carb cleaner. If so, some passages may still be blocked or partially blocked. Make sure you blow all the little passages out good with some strong air pressure. Also, I suggest getting some thin wire and run it through some of the passages to make sure they are clear. When it runs rough under load, is it making black smoke? If so, it is too rich. If not, and if it is popping while running rough, it is too lean - again an indication some passage may not be clear. What symptom did the tractor have that prompted you to rebuild the carb to begin with? In other words, are you sure you don't have another problem - say perhaps a vaccuum leak somewhere? Good luck mike durhan
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
