Re: CNH/CIH/IHC Factory 400 Carb Rebuild Kit #???
Posted by RustyFarmall on November 21, 2007 at 05:45:37 from (66.43.253.19):
In Reply to: Re: CNH/CIH/IHC Factory 400 Carb Rebuild Kit #??? posted by D Slater on November 20, 2007 at 18:34:35:
A genuine Case-IH carburetor rebuild kit will cost more like about $95. If a dealer is selling it for $65, it is more than likely not a genuine Case-IH kit, but probably is a Tisco kit, which can be purchased for about $35 from YT or any other Tisco dealer. The Tisco kit is every bit as good.
