Re: H Carb problem?
Posted by Michael Soldan on November 21, 2007 at 07:49:05 from (24.235.47.91):
In Reply to: H Carb problem? posted by Stevishere on November 21, 2007 at 04:12:25:
If you have made the proper setting on the carb it is a float problem that needs to be set .
