Re: 52' Super C..... smoking
Posted by old on November 21, 2007 at 08:26:38 from (4.244.57.38):
In Reply to: 52' Super C..... smoking posted by Josh in Maine on November 21, 2007 at 07:23:39:
If it where my tractor I would fill the cylinders with tranny fluid. Let it sit a few days, pull the plug back out, always put them back in to keep dirt etc out. Turn over the engine with the plugs out to clear the ATF, start it up and run it for an hour or so. If it was stuck rings doing that will help a lot. You can also put about a pint of ATF in the oil and a QT. into 5 gal. of gas all will help slow/stop the smoking and also clean up the engine. I use ATF because if cost less then half of the price of MMO and does the same thing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
