Re: H Carb problem?
Posted by RustyFarmall on November 21, 2007 at 11:39:45 from (66.43.253.19):
In Reply to: Re: H Carb problem? posted by Stevishere on November 21, 2007 at 10:21:27:
I don't know what manual you are looking at, but I do know which adjustment screw is which. I've rebuilt enough H carbs that I don't even look at the manual anymore.
Also, you mention that the float is disfigured. That alone will not cause problems, but usually when a float is disfigured it will also have a hole in it, and then it will not float, which is causing your over-rich problems.
