Re: H Carb problem?
Posted by riverbend on November 21, 2007 at 11:42:35 from (208.160.33.50):
In Reply to: Re: H Carb problem? posted by Stevishere on November 21, 2007 at 10:21:27:
If the carb is for an H it will have a little round brass tag rivitted on near where the shaft comes over from the governor. The tag will say something like 45108 DB (kerosene, gas will be similar but different). If it does have the tag and has those numbers on it, it is an H carb. The adjustment screw on the upper left (facing the carb) is an idle air adjustment screw.
You can check for yourself. Take the carb apart and see if that screw controls the amount of air that comes from behind the venturi and goes up to a slot by the throttle plate. The main jet is in a well under the float chamber.
Greg
