Re: c farmall engine backfires
Posted by old on November 21, 2007 at 19:50:30 from (4.245.1.135):
In Reply to: c farmall engine backfires posted by Getter done on November 21, 2007 at 17:41:14:
Firing order right?? Next the carb may not be clean enough. A carb that runs lean will cause that problem. Not sure if it has an adjustable main jet but if it does open the main up some if not you need to clean the carb better
