They completely redesigned the axle and steering mechanism. The steering setup is similar to the W series, using a Ross Steering gear. The front bolster is a steel frabricated piece and the front axle is maybe a 2 inch by 3 inch steel bar. The original A spinkles were cut of and re welded to the steel bar axle. The seat is mounted over the transmission gear shifter, and thus there is a linkage for the shifter to move the shift lever forward. The drawbar is attached to a heavy steel frame that surrounds the torque tube and the transmission housing. Final drives are rotated forward to lower the profile of the tractor. Bolting is not semetrical, so an adapter plate is required to rotate the final drives. When final drives are rotated, the brake rods point up, so new linkage required. Only one brake pedal for both sides with hand levers for individual braking if desired. Levers not very useful, as you don't have enough hands to work everything. Original mules had only a foot throttle. Many have been converted to have a hand throttle as well. Converting an A could be done, but it would be a major project.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
