Re: 52' Super C..... smoking
Posted by Steven f/AZ on November 22, 2007 at 07:15:11 from (24.121.167.138):
In Reply to: 52' Super C..... smoking posted by Josh in Maine on November 21, 2007 at 07:23:39:
Same problem with a W-9 that sat for about 20 years. I like MMO (which is probably nice-smelling tranny fluid) and SeaFoam.
Just working the engine and the normal heating and cooling cycles should eventually break the rings free.
I would also do my best to clean the sludge under the valve cover and also pull the oil pan and scrape out any sludge you can... third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
