Re: Super M stuck really hard
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by bryan on February 22, 2000 at 19:10:46 from (209.252.160.36):
In Reply to: Super M stuck really hard posted by Tim Ham on February 22, 2000 at 18:36:15:
I had a farmall m stuck on #2 and tried everthing but had no luck with oils. I cut a spark plug appart and welded a grease fitting to it. After 2 tubes of grease it broke loose! It ended up breaking the liner (which was dry) but I got it out. The old m took a new liner, set of rings, valve job, and a set of gaskets and is running fine. I also broke a 400d loose by letting it soak for monthes and rocking it back and forth.
Post A Followup
: Re: Re: Super M stuck really hard
