Posted by Bob on November 22, 2007 at 10:13:20 from (69.178.229.154):
In Reply to: Super A Piston Rings posted by BackBay2 on November 22, 2007 at 10:06:51:
If the ring set came WITHOUT instructions, return it and get a set (WITH INSTRUCTIONS) from a reliable souce.
This is TOO critical to long-term satisfaction with the engine OH to GUESS how to install the rings!
From the Hastings Piston Ring Website:
"RING INSTALLATION
All piston ring sets contain information relative to the proper installation of the rings packaged in the set.
Although in many cases most compression rings appear similar to the mechanic installing them, there are, however, many subtle design changes which dictate how the ring is correctly installed.
Not only must the ring be installed with the proper side toward the top of the piston, but it is also imperative that the ring be installed in the proper groove.
Rings installed in the wrong groove or wrong side up can lead to excessive oil pumping, excessive blow-by, and in some cases completely dry up the bore, causing ring and cylinder scuffing as well as accelerated wear. Any of these problems, of course, constitute a failure as far as an engine overhaul or rebuild is concerned."
If you INSIST on "Winging it", check out the site linked below:
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
