Re: How much MMM in the cylinders?
Posted by Janicholson on November 22, 2007 at 15:19:20 from (66.173.50.151):
In Reply to: How much MMM in the cylinders? posted by Mike CA on November 22, 2007 at 10:02:35:
Mike use the oil can method I gave you to prime the oil system. Pump typr oil can into the oil pressure gauge hole. (a bit of rubber hose will make the connection) Pump till it pumps harder (this even fills up the oil filter) It may take several oil cans full. JimN
