Re: F-20 piston rings and crankshaft
Posted by James Williams on November 22, 2007 at 19:10:24 from (74.46.215.178):
In Reply to: Re: F-20 piston rings and crankshaft posted by Scott Rukke on November 22, 2007 at 18:54:19:
Scott they keep water out of the oil.You use a sleeve puller to remove the sleeves.They are behind the sleeves at the bottom where the sleeves just go through the block.When installing new ones lubricate them with dish liquid,DO NOT USE GREASE OR OIL.A machine shop might have a puller or a press can be used with the right size disc.O rings are available at rice equipment also.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
