Re: F-20 piston rings and crankshaft
Posted by mkirsch on November 23, 2007 at 06:11:32 from (72.226.216.69):
In Reply to: F-20 piston rings and crankshaft posted by glennster on November 22, 2007 at 18:20:17:
Specifically, there are rubber o-rings sealing the gap between the cylinder sleeve and the block. It's likely that on a 70+ year old tractor that they haven't been replaced in 50 years or so, so they're probably dried out and cracked.
Dad says you can replace the cylinders on these engines right in the field, so the sleeves should be downright simple to remove.
