Re: A Back Fires When Shut Off
Posted by mkirsch on November 23, 2007 at 06:17:37 from (72.226.216.69):
In Reply to: A Back Fires When Shut Off posted by glennster on November 22, 2007 at 15:22:05:
Just out of curiousity, are you working the tractor hard?
Backfiring is normal if you're working the tractor hard, because the combustion chambers are hot enough to cause the gas to ignite on their own.
If you're just playing around, it may be that you have your air/fuel mixture too lean, and the engine is getting hot from that. It may behoove you to open up the load screw on the carburetor some to let more fuel in.
