Re: F-20 piston rings and crankshaft
Posted by El Toro on November 23, 2007 at 07:30:57 from (64.12.116.73):
In Reply to: F-20 piston rings and crankshaft posted by Scott Rukke on November 22, 2007 at 18:20:17:
You should clean that block area thoroughly around and under where the sleeves & seals sit. Dirt and rust are probably in that area. Be sure to use some dish detergent to coat the lower area of the sleeve so they will slide into that new sleeve.
If there's a recessed area in the top of the block for the top of the sleeve to sit you need to clean that area too. If the F-20's are similar
to to the Farmalls you probably need to pull the damper from the engine. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
