Re: F-20 flywheel and engine support
Posted by Kevin LA-CA on November 23, 2007 at 10:07:15 from (71.189.147.139):
In Reply to: F-20 flywheel and engine support posted by Scott Rukke on November 20, 2007 at 14:29:23:
I was even lazier. I just threaded in long bolts in each puller hole. These were turned against the back of the bellhousing. By alternately tighting the bolts, the flywheel was pushed off the crank. Just turn the flywheel so the 3 bolts press against the housing, not mounting bolts.
kevin
