Re: Super A gurgling sound after shut-off
Posted by Wayne in Minnesota on November 23, 2007 at 11:37:42 from (66.228.243.49):
In Reply to: Super A gurgling sound after shut-off posted by ddg on November 23, 2007 at 07:36:16:
Are you sure that the engine isn't turning backwards after you shut-down? Take a look at the fan blades & watch to see if they rotate backwards for a moment. Solution: Idle the engine down, let it cool for a bit, turn the ignition switch off & let out the clutch while in gear to stop any further engine rotation.
