Re: 1939 A
Posted by glennster on November 23, 2007 at 13:50:50 from (76.224.26.7):
In Reply to: 1939 A posted by MTC on November 23, 2007 at 13:42:12:
two things come to mind that would be (easy) ???? fixes. first, head gasket leaking, second the o rings at the base of the cylinder sleeves are leaking. drop the oil pan, fill the radiator and look for leaks at the cylinder bottoms. if you want to try and pressurize the cooling system to check for leaks, get a bicycle innertube for a fat tire bike, cut thru it opposite the valve stem. hook one end to the lower rad outlet on the motor, add antifreeze to it and hook the other end to the top going in to the block. pump it up with a hand tire pump, get 5-6 psi of air pressure in there and check for leaks. you need a couple hose clamps on the innertube too!!
