Re: Super A gurgling sound after shut-off
Posted by Hugh MacKay on November 23, 2007 at 17:13:33 from (209.226.106.131):
In Reply to: Super A gurgling sound after shut-off posted by ddg on November 23, 2007 at 07:36:16:
ddg: Quite normal, Super As have been doing that for 60 years. Yes, they did it when they were hot off the assembly line and they still do it.
You can help the situation, maybe even eliminate the gurgling, all it requires is two minutes idling before shut down. Remember it took 5 minutes to feed and groom the horse at the end of the day. Surely you can groom the SA for 2 minutes. They were both part of the evolution.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
